cancel
Showing results for
Did you mean:
wifi connection
Gussuyo11
Level 1
1 of 4
I have a problem with the wifi connection to my mobile phone.
I cannot connect with it. If I will enter the code or password of the wifi it will connect. What should I'm going to do? Please help me.
3 Comments 3
Black Mamba
Level 1
2 of 4
@Gussuyo11
restart the phone and the router used for the Wifi connection
if the problem persists contact the Swisscom Hotline
Select your request and contact Swisscom by hotline, chat or text message
Zisezi33
Level 1
3 of 4
I lost my internet-Box pass word
Black Mamba
Level 1
4 of 4
Router password, Swisscom login, WLAN data: How to log on
Router password
To manage your Internet-Box settings, go to the web portal by entering 192.168.1.1 or http://internetbox.home in your browser. Please note that you can only access the web portal when your home network is connected to your Internet-Box. The user name is “admin”. If you forget your router password, you can reset it in the My Swisscom Customer Center. Click on your Internet subscription > “WLAN & Router” > open the “Router” section at the very bottom. Reset your password under “Router password”. Change now
Back to top
