cancel
Showing results for
Search instead for
Did you mean:
SOLVED
tethering download speed
Contributor
1 of 3
Hello
Since I got  a new phone, xperia xz1 compact, my download speed when using USB Tethering has been reduced to 1Mbps.
Upload speed is fine, > 30Mbps.
Doing a speedtest on the phone itself shows a download/upload speed > 30Mbps.  This does not happen with WiFi tethering, only with USB.
If it helps, the computer is a Linux machine, Debian 9, which works perfectly fine with my old phone (HTC 10).  The HTC was not a Swisscom branded phone, whereas the xperia XZ1 Compact is purchased from Swisscom.
Does Swisscom throttle download speeds when using USB thetering, or is it likely some other hardware-related issue?
Thanks!
MOST HELPFUL ANSWER
Accepted Solutions
Contributor
3 of 3
It was actually a software issue with the phone.  The latest firmware fixes the issue.
2 Comments
Contributor
2 of 3
I've tested it on Windows and it's fast, so I guess it's not a Swisscom issue but more likely a compatibility issue between this phone and my Linux.
Contributor
3 of 3
