cancel
Showing results for
Did you mean:
SOLVED
Mobile telephony impaired
JoelV
Level 1
1 of 2
Dear Community
This afternoon between 14:33 and 14:48, telephoning via the mobile network, sending SMS and MMS as well as using the mobile internet were affected by a disruption throughout Switzerland.
The situation is returning to normal, but there may be restrictions for some customers. We apologise for the disruption.
Information on the status, as well as the possibility to be notified by SMS:
https://www.swisscom.ch/en/residential/help/network-and-service-status.html
Business Owner | Communications Manager Swisscom
ACCEPTED SOLUTION 1
Accepted Solutions
JoelV
Level 1
2 of 2
Phone calls via the mobile network and data connections are fully available again. If Swisscom services do not work as usual, restart your mobile device. The cause is currently unknown and will be analysed in detail later.
We apologise for any inconvenience caused.
1 Comment 1
JoelV
Level 1
2 of 2
Back to top
