How does the Internet-Box respond to power failures?
50% helpful (1/2)
With the latest fixed network telephony (IP), the phone is dependent on the Internet connection, and therefore also on the power supply. So, what should you do if there is a power failure?
You will be unable to make calls during a power failure. We therefore recommend that you set up call forwarding in the Swisscom Customer Center for this eventuality.
Worth knowing:
You don’t need to reconfigure your Internet-Box when there is a power failure. Simply wait until everything starts up again.
This is a user-generated article. Please note that the content of this article does not necessarily represent the views of Swisscom.
Was this article helpful? Yes No
