cancel
Showing results for
Did you mean:
SOLVED
No connection following my move
Meflunguth82
Level 1
1 of 4
I’ve just moved into a new apartment and have installed my swisscom box. but it is saying there is no Internet Connection. I got a confirmation saying my router has been installed but the WLAN doesn’t seem to be working. What have I done wrong? I followed the installation guidelines. I’m thankful for any tips and input. cheers
Edited
ACCEPTED SOLUTION 1
Accepted Solutions
Meflunguth82
Level 1
3 of 4
Hi LeylaG
yes thank you. i ended up restarting the whole set-up process and finally i managed to get a signal.
thanks
3 Comments 3
LeylaG
Community Manager
2 of 4
Hello @Meflunguth82
Welcome on the Swisscom Community.
Is the situation resolved in the meantine?
Un like fait toujours plaisir 😉 Une réponse t'a aidé? -> Accepte-la comme solution!
A like always brings a smile 😄 Don't forget to accept helpful solutions
Meflunguth82
Level 1
3 of 4
Hi LeylaG
thanks
LeylaG
Community Manager
4 of 4
Hi @Meflunguth82
Great, thank you for your feedback.
Have a good day
Back to top
