cancel
Showing results for
Search instead for
Did you mean:
Internet speed on 100 Mbit/s connection
Novice
1 of 3
Hi everyone,
I was just wondering if on my 100 Mbit/s connection, a speed of 82 Mbit/s is considered normal?
No matter how many times i repeat the speed test under different circumstances, it never goes higher than 85...
Should i ask for someone to check the connection?
2 Comments
2 of 3
I guess you have a copper line. In this case: yes, that is due to a lot of factors.
It's "up to" 100 mbit but your line and installation needs to deliver that speed, too.
Novice
3 of 3
I can only seem to get 10-11MBps from Internet speed - is there any way this can be improved at all ?
I have not yet connected a TV to the Internet Box, as I am wondering if the internet speed is too slow to get good quality TV
