cancel
Showing results for
Did you mean:
SOLVED
Difference Wlan and Internet box
vladg88
Level 3
1 of 2
Hello,
I currently have an internet box 2 with a separate tv box as part of my M Internet and M blue tv subscription.
I received an offer to upgrade to a WLAN box 2, but i do not understand the difference between the WLAN box and the internet box.
Can you please advise because it's not clear from your website and products.
Thanks in advance,
ACCEPTED SOLUTION 1
Accepted Solutions
Black Mamba
Level 3
2 of 2
@vladg88
thanks for contribution
> ... Can you please advise because it's not clear from your website and products. ...
the WLAN Box or WLAN Box 2 serves as a repeater or amplifier of the wifi signal in a home in places where it would be of poor quality, it can also be used to connect a TV-Box.
an Internet-Box 2 or other is a router for connection to the public Internet network.
the WLAN Box needs a router to be functional must be synchronized with the router.
WLAN-Box 2 – Network Accessories | Swisscom
  • Extends the range of your existing WLAN
  • Connects the TV-Box and other devices to the Internet-Box (router) wirelessly
  • Can be extended with up to 4 WLAN-Boxes
  • Flexible positioning thanks to mesh function
  • 3 × 1 Gbit/s Ethernet connections
  • Supports the latest WLAN standard (Wi-Fi 6)
  • Automatically connects to the best WLAN network
  • Installation at the touch of a button
WLAN-Box 2 guarantees optimum WLAN reception. It is ideal:
  • For combating poor WLAN coverage in your property.
  • For use in detached homes and large or multi-storey apartments and office buildings.
  • If your router is installed in a wiring cupboard.
WLAN-Box 2 also offers a number of useful functions in one device:
  • It extends the WLAN range of your Internet-Box as a repeater or WLAN Access Point.
  • It connects your TV-Box wirelessly to the Internet-Box To do this, connect the WLAN-Box 2 to the TV-Box via Ethernet cable.
  • Thanks to the integrated mesh function, you get more WLAN range and can place up to 4 WLAN boxes flexibly.
Edited
1 Comment 1
Black Mamba
Level 3
2 of 2
@vladg88
Edited
Back to top
