cancel
Showing results for
Search instead for
Did you mean:
ip passthrough not working
Highlighted
Level 1
1 of 1
Hi,
i am running a centro with firmware 6.16.12
the centro has ip address 192.168.0.1 and behind my centro i run an router with ip adress 192.168.1.1.
I configured the centro to ip pass through to this router and i see in my router that the WAN ip is the same as the centro WAN ip.
Behind my router with ip 192.168.1.10 i am running a apache web server and the router is configured to expose he apache as virtual server.
Everything was running successful for a while and suddenly it stopped working.
Somehow my web server is not anymore accessible from outside.
I have done the following during trouble shooting:
I can access the web server from the inside LAN under the dynDNS name.
I cannot ping my external IPv4 address of centro from an external server ping.
What could be the issue?
Any advise on how to further investigate?
thanks
Back to top
