cancel
Showing results for
Did you mean:
Swisscom Smart Switch is here!
JoelV
Level 4
1 of 1
Smart adapters are becoming increasingly popular in smart homes. These Smart Switches help you control devices and lighting or save electricity. With the new Swisscom Smart Switch, you too can join the smart home movement – quickly and easy with the Swisscom Home app.
What you need to use Smart Switch
All you need to be able to install and use the Swisscom Smart Switch is a Swisscom Internet-Box (standard, plus, 2, 3) and the free Swisscom Home app.
Functions of the Swisscom Smart Switch
With the Swisscom Smart Switch, you can control connected devices from anywhere at any time. You can also define rules for switching it on and off automatically. The Swisscom Smart Switch is operated via the Swisscom Home app. The white status LED can also be easily deactivated from the Home app.
Order the new Smart Switch now from the Online Shop and try it out. For more information, see the Swisscom help page.
Already using a Switch at home? For which device would you like to purchase an additional Switch?
Have fun connecting your household!
Best regards
IvanH
Business Owner | Communications Manager Swisscom
Back to top
