cancel
Showing results for
Search instead for
Did you mean:
SOLVED
Setting WLAN to b/g only
Highlighted
Level 1 AML
Level 1
1 of 2
Is there any way to set the wifi signal to b/g ONLY as opposed to the standard b/g/n on the Swisscom Internet Box 2? This is apparently the only way to ensure my robotic mower (Worx Landroid) can connect to WiFi. It seems like this is not an option in Expert mode.
MOST HELPFUL ANSWER
Accepted Solutions
Highlighted
2 of 2
Sorry, if you can't see this option, than you can't configure it.
1 Comment
Highlighted
2 of 2
Back to top
