cancel
Showing results for
Did you mean:
SOLVED
Evziz Camera non connecting to network
Wappeyau15
Level 1
1 of 4
I've bought a Wi-fii camera Evziz 3CA but the setup fails.
I've setup on the Internet Box2 a 2.4ghz Alan but the issue still there.
The Evziz support ask if port 80/554 is not restricted by the ISP.
Where can i check resp. setup this port?
thank you
ACCEPTED SOLUTION 1
Accepted Solutions
Wappeyau15
Level 1
3 of 4
Yes, they solved restarting all the system not only the app 😉
Support was faster than community, didn't expected that but at the end the result counts 🙂
Thank you and keep safe
3 Comments 3
LeylaG
Level 1
2 of 4
Hello @Wappeyau15
I noticed that you called our customer support.
As I understand it is now working after re-installing the app and the device connected to the WLAN.
Un like fait toujours plaisir 😉 Une réponse t'a aidé? -> Accepte-la comme solution!
A like always brings a smile 😄 Don't forget to accept helpful solutions
Wappeyau15
Level 1
3 of 4
LeylaG
Level 1
4 of 4
@Wappeyau15 Thanks for the detailed information 👍
I wish you a nice weekend 🙂
Take Care
Back to top
