cancel
Showing results for
Did you mean:
SOLVED
DynDNS on LTE router with CAA
mbernasocchi
Level 1
1 of 2
I wanted to access the network behind my LTE router.
In the normal case, a mobile data connection gets an RFC1918 (private) IP (see https://community.swisscom.ch/t5/Archiv-Internet/Dynamic-DNS-possible-with-Swisscom-quot-Natel-Data-...) like 10.*.*.* .
So I can't have a DynDNS running.
ACCEPTED SOLUTION 1
Accepted Solutions
mbernasocchi
Level 1
2 of 2
I called the hotline and a super nice supporter activated CAA for me (5CHF/month) for all my multi sim.
I tested it with a secondary data-only sim and it worked flawlessly.
I had to change the APN to corporate.swisscom.ch (empty user, empty password), disconnect my router (or just reboot it) and I got a publicly routable IP, which means I can now run my VPN server, DynDNS and all I want...
Thanks a lot support 🙂
Edited
1 Comment 1
mbernasocchi
Level 1
2 of 2
Edited
Back to top
