cancel
Showing results for
Did you mean:
Connecting computers via WLAN box
Alice34
Level 1
1 of 4
I have two Mac computers on different floors, both on the same WLAN network connected to Internet Box 2. I used to transfer files from one computer to the other via the WLAN network (using cmd+K in the Finder). After I installed a WLAN Box, the two computers can no longer communicate via the WLAN network. The other computer no longer shows in the list of available servers. Can this be corrected?
3 Comments 3
DomiP
Level 1
2 of 4
Have you paired the WLAN-Box correctly like mentioned in the Manual?
Try to use the Swisscom Home-App to pair the Boxes properly.
Gruess, Cordial salids, Cordialement, Cordiali Saluti, Cheers!
Dominik
Alice34
Level 1
3 of 4
Of course I did, with the Swisscom app, what's more. The internet connection works perfectly, but as I said, the devices connected to the Internet box cannot communicate with the devices connected to the WLAN box (as indicated in the network topography).
Black Mamba
Level 1
4 of 4
@Alice34
thanks for contribution and feedback
you have to try a REBOOT / RESET of the different devices
Back to top
