cancel
Showing results for
Search instead for
Did you mean:
Connect my pre-ampli to the radio signal of Swisscom TV 2.0
Highlighted
Level 1
1 of 2
I want to connect my pre-ampli to the radio signal of Swisscom TV 2.0 via a cinch analog cable. My system is fairly old, but the high end from Technics which cost me 25 years ago more than $ 4000.
I only find one of the stereo connections with signal, the red cinch but the white cinch is dead. What ever I do it remains dead.
The ampli functions perfectly on a internet radio (3 years old) as well as on a satellite receiver (2 years old), both fitted with red and white cinch connections.
Any suggestions what I can do?
Thank you
Edited
1 Comment
Highlighted
Level 2
2 of 2
Quite an old question without any response yet...
Just some thoughts:
  • The TV 2.0 box does not have Cinch, but I think it has 3.5mm audio jack as far as I know.
  • There are 3-pin and 4-pin 3.5mm audio jacks while the 4-pin ones (3 black rings) are used mainly for laptops which use 4 wires (ground, left, right, mic) while the 3-pi ones (2 black rings) are used often in audio equipment (ground, left, right). I guess you're using a 3-pin 3.5mm jack to 2x cinch adapter. But I am not sure if the 3.5mm jack on the TV 2.0 box is 3 or 4 pin; as far as I know it's combined with optical S/PDIF too.
So you might check your cable or use another one just to try. Another (even better) option might be to use the audio out available on most TVs to hook it up to your amplifier. So connect your TV 2.0 box via HDMI to your TV and use the audio out on your TV to connect it to the amplifier. This wasy you might also get better A/V sync as most TVs cause some output delay and they also delay the audio out on those jacks. If you feed the audio directly from TV 2.0 to your amplifier the audio might be aut of sync with what's shown on screen by a few milliseconds.
Back to top
