cancel
Showing results for
Did you mean:
SOLVED
CAA option on Multi Device
zAZA99
Level 1
1 of 8
Hello everyone,
is it possible to have a public IP on a Multi Device SIM Card?
This is possible with the CAA option on normal phone subscriptions, but no one can tell me if it's possible on a Multi Device SIM card.
Thank-you!
ACCEPTED SOLUTION 1
Accepted Solutions
LeylaG
Level 1
2 of 8
Hello @zAZA99
If the CAA Option is activated on your contract, you should be able to use it also on the additional device. You have to set up again the device with the apn corporate.swisscom.ch
Hope it helps!
Un like fait toujours plaisir 😉 Une réponse t'a aidé? -> Accepte-la comme solution!
A like always brings a smile 😄 Don't forget to accept helpful solutions
7 Comments 7
LeylaG
Level 1
2 of 8
Hello @zAZA99
Hope it helps!
wmeter
Level 1
3 of 8
I confirm that it works fine, I use the option on both the main SIM and on the additionals. I receive a public IP on all devices as long as I use the correct APN.
mcbeee
Level 1
4 of 8
Hallo zusammen. Ist diese Information immer noch gültig? Nutze CAA schon seit vielen Jahren und bin mir am überlegen auf eine Multi Device Sim zu wechseln. Bis jetzt separate Data Sim. Wäre massiv schneller unterwegs und ohne Datenlimit von 10GB. Hoffe die CAA Option ist immer noch buchbar.
LeylaG
Level 1
5 of 8
Hallo @mcbeee
Maybe @Diogo Ferrario can help you?
Thienniesseum97
Level 1
6 of 8
Hallo,  soweit ich informiert bin, kann CAA NICHT mehr gebucht werden - egal, ob geschäftlich oder privat.
Dieser Dienst wird abgeschaltet.
Edited
mbernasocchi
Level 1
7 of 8
Black Mamba
Level 1
8 of 8
for those who are interested
maybe this discussion can help 😀
Solved: DynDNS on LTE router with CAA | Swisscom Community
post from @mbernasocchi at 03.08.2021
" ... I called the hotline and a super nice supporter activated CAA for me (5CHF/month) for all my multi sim.
I tested it with a secondary data-only sim and it worked flawlessly.
I had to change the APN to corporate.swisscom.ch (empty user, empty password), disconnect my router (or just reboot it) and I got a publicly routable IP, which means I can now run my VPN server, DynDNS and all I want...
Thanks a lot support  ... "
Back to top
