Hello everybody, I've recently applied for the Internet Booster option and I got immediatelly a 3rd generation Router and an internet booster antenna.
Everything went fine with the Router, indeed the Booster was not attaching to the Mobile Network.
After few hours of troubleshooting 2 days of patience, Swisscom apparently fixed the problem and the Booster was finally connecting to the mobile network.
The problem I'm still facing is the following:
1) Even if the connection to the mobile network is quite good, each 5/10 minutes the Booster is loosing the connection and it reconnects by himselt;
2) Even when the connection is up&running, I don't get any Mbit from the Router.
Any idea what might be the issue? I strongly suspect is something at configuration level at Swisscom, but I cannot be sure.
Fyi, the Mobile Signal Strength shown in the Web Admin Page of the Booster, says -93 dB (3 bars out of 5).
Thanks,
Claudio.
