@"x"#p5898
Centro Grande is a triple play device. The br0 is the internal network (LAN ports WLAN AP's) Swisscom TV needs multicast to work. Multicast is like a radio signal for IP. (send to many not only to one)
If you don't have Swisscom TV you could disable it. But I wouln't. It doesn't affect you in any case.
Go to command line (telnet)
telnet 192.168.1.1
admin
your password
conf
set /dev/br0/mcast/enabled 0
reconf 1
Swisscom TV users can try this an see your stream stopping. Doing the same but
set /dev/br0/mcast/enabled 1
reconf 1
and the stream starts to work as usual.
