Hi,
I bought a Montreux phone a couple of weeks ago, and it connected to my Wireless Internet box real easy, and was working fine. Then, for no reason at all, it dropped the connection to the Swisscom router and now it will not re-connect. I select Settings –> Advanced Settings –> Connection, press the “+” button on the router, and it does not find it at all. I’m next to the router, so it cannot be the signal strength. I also tried a Factory Reset and to no avail.
Anyone have any other suggestions please?
Thanks!
