Hi @bitracer
As @POGO 1104 already mentioned, the consumer WLAN-Boxes are incompatible with the CB.
Even if the WPS pairing would succeed or if they would be connected directly via Ethernet, there would be no way to configure them.
They do not clone the Wi-Fi they connect to via WPS, but fetch the configuration from the Internetbox. If there is no Internetbox, there is no Wi-Fi đ
Best,
r00t
