@Wockupu77
the site www.swisscom.com/help is not secure: http://...
on the other hand, it is not referenced, hence the redirection to the Swisscom connection page
please inform which is the source of this URL link 🤔
please visit this page to access the router
Optical fibre access availability, OTO ID Check − Help | Swisscom
Web portal of the Internet-Box
Internet-Box web portal: you can also measure the speed between the Internet-Box and the Internet in your Internet-Box web portal. To do this, enter 192.168.1.1 in the browser field orhttps://internetbox.homeand perform a speed test. Please note that you only have access to the Web portal when your home network is connected to your Internet-Box.
What is the OTO number (OTO ID) and where can I find it?
If your home is connected to the fibre-optic network, you will usually have a fibre optic socket. You will find it in your living room or hallway. The fibre-optic socket will show the OTO number or OTO ID – a sequence of numbers and letters for identification. > Router set-up instructions
follow the instructions provided on these pages
How to set up the router and Internet - Help | Swisscom
thanks for a feedback 😀
