@suisse I use the WLAN Connection adapter for the Swisscom TV 2.0. First few months it worked flawless, but the last week or so I need to reset (switch off and on both units) few times a day. Otherwise there is no internet connection. The checkmark on both devices is green, so indicating that everything is ok.
After the reset the connection is ok and works until the TV is switched off. Problem again when I switch it on later that day or next day.
Any ideas?
