Inserting the USB modem stick into my MacBook Pro automatically runs the UCM software. Sometimes the "enter PIN" box doesn't appear, instead "Insert Device". How can I tell the UCM software to try again?
Rebooting the Mac usually fixes it, but that breaks running applications.
A common use-case is creating a GSM Internet connection, then running VMware MS-Windows XP and using software there. This has worked fine since May 2011 (barring the problem above), but now when VMware starts Windows, the UCM software disconnects and shows the "Insert Device" message. Windows then says "new hardware found" (even though I tried to disable this in VMware), but installation doesn't success. This is after some recent "manditory" Microsoft updates. Any ideas?
In this case, I really need a way for UCM to see the USB again and connect to the Internet without rebooting.
Huwei USB modem, "Mobile Broadband E173"
UCM 4.2, build 130107.135749
MacBook Pro, early 2011
MacOSX 10.6.8
Vmware Fusion 4.1.4
MS-Windows XP
