Wifi issues with MacOS on 2018 Macbook Pro M1 on Ventura 13.6.3
Hello
I permanently lose connection completely randomly but sometimes within minutes apart from each other.
I can get back to a connection by “switching off” Wifi on my Macbook and re-activating it. Then chose either my 2.4Ghz or 5Ghz Wifi SSID, but this will be again only for a couple of minutes.
Interestingly: this does NEVER happen when my Macbook is connected using a 4G mobile hotspot and ONLY when connected to Swisscom Home Wifi.
I have other devices (Android, Windows, Smart TV, PS4, etc..) and all of them behave fine and never lose connection over WIFI - so what is the catch?
My Mac is on the latest supported OS
My router was rebooted several times (IB3)
I have one WLAN-box per floor for increased/better connectivity.
I am literally at 5 meter distance from the WLAN box.
Only the MAC behaves like this.
I’m getting frustrated!
Best regards,
David
