Hi, I have my internet box 3 (IB) in a wiring cabinet - yes, I know not ideal but forced to do this in our new build. In addition, I have 2 WLAN-Box-2 devices. One is at far end of house and connected to IB by ethernet - works fine. Other is closer to IB and is also connected by ethernet cable. However, on Home App it shows as connected to IB by WiFi - I presume it has done this automatically as a WiFi signal is available, if perhaps weak.
My question is: does it make sense to force (how?) the closer WLAN box to connect to IB via Ethernet for higher speed or should I simply ignore it and continue with current setup where WLAN box connects to Internet box which is a wiring cabinet?
Thank you for suggestions.
