Hm.
i use even 4 10gbs connection, may in this case my needs are extraordinary, but especially because of corona the need occurred even higher.
Trading each and every day with gigabyte and terrabyte of data for sync, backup and exchange with clients because i gonna call my self kind of videoproducer. a single port is important to me. and also time matter. events will shut down, and the content has to be ready for post production. an hour of record take about 800gb data, getting from studio, work on it and send it back. and usually client want it already yesterday. our system is supporting bounding and bridge.
after download he will do first backup of everything, 1 home based storage, 2 cloud based storages, as well as home storage uses a 2nd cloud based storage for backup, so 800gb by 4 times just one in home office. so you gonna go wait? doing some kind of holiday? about 4hours after event you gonna send your client all records, but with quality check as raw files, therefor upload everything, after you had to render some stuff. 4h hours gone, you traded about 5tb of data, sure i want my 2.5gbs port and gonna go to bali until shit is done
because of people who want to think for their clients, we cant develop in a speed, we would like. someone decided, we dun need 10gbs in one port, even though its already to slow. we have to go to an office, and work from this place. also most products are kmu/office only, prices are extraordinary and so on. F**** the wifi 6, duno for what i need this. in switzerland my 4g is doing usually better than any installed wifi networks and in flat almost all devices connected by cable anyway, you wont connect a sonos by wifi, kinda stupid. but i had to invest a huge amount of money, to make my home a homeoffice. gonna try by your own, go to swisscom shop and tell them, you would like to have about 40gbs. sure i dun use swisscom boxes or sunrise boxes or salt. wont work. and sure enough i had to install a back up internet for redundancy, which isnt cable based, wont make sense.
My point is: don’t decide for your customer, this way you block everything, make everything more complicated, sure enough more expensive, but mostly slow down evolve.
