lucafik I have a pretty old Centro Piccolo router. I tried everything, from restarting to changing cables. Are there any known problems with this routers? I have it for 3 years already.
LeylaG Hello lucafik, Have you tried to reset the routeur? If the situation persists we can arrange a call back from our technical support. Cheers
lucafik I got it to work in the end. No idea what the problem was. I restarted it multiple times.. ordered a new one so it should make less problems I guess
KatrinM Good morning lucafik We would like to thank you for your feedback. It is very good to hear now everything works fine again. Kind regards
