Tenzinno74 how do you reinitiate the remote to link it to the tv-box because the remote doesn’t switch on or off the tv and the tv-box? Thanks
WalterB Tenzinno74 Schau Dir mal den Link unten an. https://community.swisscom.ch/d/840832-tv-update-tipps-fur-die-storungsbehebung
