Hi and thanks for your response
I tried the server you mentioned but the phone would not connect. Under “Local Phone Credentials” in my Swisscom router I see the following instructions:
Your local SIP phone must be set up once with the phone credentials and connection settings. Please use the following setting parameters for this purpose. Please note that every SIP phone manufacturer uses different terminology and not all parameters need to be configured for every SIP phone.
Authentication user name: Your authentication user name defined aboveAuthentication password: Your password defined aboveUsername: The internal phone number matching your phone credentials (e.g. 220)Display name: Your nameDomain: 192.168.1.1Proxy server address: 192.168.1.1Proxy server port: 5060Registration server: 192.168.1.1Registration port: 5060STUN server: NoOutbound proxy address: 192.168.1.1
So I put fs1.ims.swisscom.ch as the SIP server, this did not work. I tried it as the SIP server with 192.168.1.1 as the outbound proxy, which the phone thought was working but I still could not make outbound calls. Having 192.168.1.1 as the SIP server with fs1 as the outbound proxy makes no sense since the fs1 server won’t know how to get to 192.168.1.1 (though I did try it anyway, and it did not work).
It’s still not clear to me what settings I should be using.
Thanks
