Hello,
I am trying to host a server on an online game, but even if the game is starting the server the other players can’t see it. Looking at the game forums it’s suggested to set Port Forwarding to manual with below instructions:
QUOTE
On many router models you can access the settings by navigating to [omit] using your web browser, finding the port forwarding settings (sometimes called “application sharing”) and forwarding one of the ports using the following settings:
Game port (used to communicate with clients)
Service/Application: barotrauma
External Port: The port you have selected for your server (27015 by default)
Internal Port: The port you have selected for your server (27015 by default)
Protocol: UDP
Query port (used to communicate with Steam)
External Port: The port you have selected for your server (27016 by default)
Internal Port: The port you have selected for your server (27016 by default)
Protocol: UDP
UNQUOTE
Can you please assist me understanding how to input these settings into router settins?
I have the “Internet -Box plus” router, I managed to enter in its setting, switched to expert mode, but I am not sure how to set the Port Forwarding rules based on above instructions.
Any help will be much appreciated!
