Hi Walter. Yes the filesystem is defective. Here is a serial output from the board:
HELO
CPUI
L1CI
HELO
CPUI
L1CI
DRAM
PHYS
STRF
400H
PHYE
DDR3
SIZ4
SIZ3
DINT
USYN
LSYN
MFAS
LMBE
RACE
PASS
ZBSS
CODE
DATA
L12F
MAIN
NAND flash device: name, id 0xecf1 block 128KB size 131072KB
TRACE: SA_BootNandGetHardwareVersion,399, Hardware version <2.3.0>.
External switch id = 53125
ERROR: SA_StructRead,224, CRC32 mismatch in block 5 (partition 3), read ffffffff, calculated 47c5000b.
ERROR: SA_StructRead,224, CRC32 mismatch in block 6 (partition 3), read ffffffff, calculated 47c5000b.
ERROR: SA_StructRead,224, CRC32 mismatch in block 7 (partition 3), read ffffffff, calculated 47c5000b.
ERROR: SA_StructRead,224, CRC32 mismatch in block 8 (partition 3), read ffffffff, calculated 47c5000b.
ERROR: SA_StructRead,273, Could not read structure type 5 from partition 3
ERROR: SA_GetBootImageState,356, Could not read BOOT OPTION structure, leave.
ERROR: SA_GetSplashScreenState,312, Could not read BOOT OPTION structure, leave.
RA8875 device id=0×75
Use PWM divider 3
CFE version 1.0.38-114.185 for BCM963268 (32bit,SP,BE)
Build Date: Thu Jan 16 18:19:46 CST 2014 (macdux@macdux-System-Product-Name)
Siligence/Askey version: 01.03.03.s10
Copyright © 2000-2011 Broadcom Corporation.
Chip ID: BCM63168D0, MIPS: 400MHz, DDR: 400MHz, Bus: 200MHz
Main Thread: TP0
Memory Test Passed
Total Memory: 268435456 bytes (256MB)
Boot Address: 0xb8000000
Board IP address: 192.168.1.1:ffffff00
Host IP address: 192.168.1.100
Gateway IP address:
Run from flash/host (f/h): f
Default host run file name: vmlinux
Default host flash file name: bcm963xx_fs_kernel
Boot delay (0-9 seconds): 1
Board Id (0-37): RTV1825VWC2
Number of MAC Addresses (1-32): 6
Base MAC Address: 7c:b7:33:02:ee:99
PSI Size (1-64) KBytes: 24
Enable Backup PSI [0|1]: 0
System Log Size (0-256) KBytes: 0
Auxillary File System Size Percent: 0
Main Thread Number [0|1]: 0
Serial Number: 4.01409F0449982
Voice Board Configuration (0-0): SI32261_DCX81
*** Press any key to stop auto run (1 seconds) ***
Auto run second count down: 1
Port 3 link UP
Port 7 link UP
ERROR: SA_GetValidBootPartition,1177, Can not read boot option, use default one.
ERROR: SA_GetFileContent,988, Unable to find entry for file sa.sig.
TRACE: SA_BootNandErasePart,755, Partition 7 erased successfully
TRACE: SA_BootNandErasePart,755, Partition 8 erased successfully
ERROR: SA_GetValidBootPartition,1205, None of boot image has requiered headers!!
TRACE: SA_BootFromNand,1321, ** No valid parition found. **
web info: Waiting for connection on socket 0.
CFE>
CFE>
Port 3 link UP
Port 3 link DOWN
web info: Waiting for connection on socket 1.
web info: Waiting for connection on socket 2.
web warning: Unexpected TCP disconnect.
web info: Upload 43123321 bytes, invalid image format.
web info: Upload 32244109 bytes, invalid image format.
CFE>
I can see that partition 3 of the filesystem is corupted. Unfortunattely I’m not familiar with the specific filesystem of the IBP.
You can see at the end 2 atempts to upload the firmware R09 and R10 but each time I have an error because the image format. As I already said the image we can flash from the normal user interface is not adapted to be flashed from the CFE bootloader.
Best regards,
ssr
