New mobile phone
I have forgotten my username and which email we did it with it is on my wife’s name we don’t know how to find our username or email
  • gian has responded to this post.
    Which user name is meant ?
    From TV ? (you write here in the UNterforum “TV”)
    Username from MySwisscom ?
    Username from Smartphone ?
    If you don’t remember your MySwisscom username, follow the instructions in the login window under “Forgot password” and/or “Forgot username”.
    ….keep on rockin' 🤘🏼🤘🏼🤘🏼
    Stulluple79 I forgot my username and what email we did it with it’s on my wife’s name we don’t know how to find our username or email
    This is annoying and can be avoided by using a password manager. My Proton password manager stores all passwords and notes etc. absolutely securely in the Proton Drive (cloud from Proton, a Swiss company based in Geneva). This means I always have access to my passwords on my PCs, smartphones and tablets, because every service I use has its own passwords that are simply impossible to memorise.
    Of course, you could also create a password table using Excel, but it’s quite tedious and there’s a high chance of typos. Such a table is also unprotected and can be viewed by anyone who has access to the PC. This problem doesn’t exist with password managers, because when I open the password manager, I always have to authorise access first with a code, password or fingerprint (smartphone). I’m happy to accept that for a little more security.
    If you don’t know the username or email address used and the password, you’re in a bad position with any provider. It usually helps to create a new user account with the relevant provider. If you know the e-mail address, you can have the password reset and set up a new password.
