WLAN Box 3
It is not possible to connect the W-Lan Box 3 with the Ethernet cable. My question: does the box always have to be connected to the power supply? Thank you very much
Yes, the WLAN box must always be connected to the power supply for operation.
A power supply via PoE (power via Ethernet) is unfortunately not supported
….keep on rockin' 🤘🏼🤘🏼🤘🏼
