Hello all,
I am having a strange issue when trying to use a Guest WLAN on a topology that uses an Internet Box 4 and a WLAN Box 3 at home. The Guest WLAN (encryption WPA2/3, set to never turn off) can be ****nected to when *necting to the Internet Box 4 (area of the house where the signal of the Internet Box 4 is strongest) and it works well in that case. However, when in the area covered by the WLAN Box 3, the *nection to the Guest WLAN is completely unstable at best, or simply does not work/allow devices to ****nect to it (e.g., stuck on the “registering IP address” step). The regular “non Guest” WLAN works perfectly on both access points (Internet Box 4 and WLAN Box 3).
I have already tried the following actions, without success:
Update the firmware
Change the SSID of the Guest WLAN
Change the password of the Guest WLAN
Turning off/on the Guest WLAN
Resetting the WLAN Box 3
Resetting the Internet Box 4
Re-doing the pairing process of the WLAN Box 3 to the Internet Box 4
Have you had the same issue? Am I missing something? Any help will be welcomed.
Best,
F
