Update
  • Good morning,
    I have 2 TV-Box 21. Since the update, one works very well while the other has very frequent image cuts.
    how to correct this.
    • Hello @JoeBar56,
      Try doing a reset with a sharp object in the small hole marked RESET.
      Take care to connect the box to the router with a cable to carry out this operation.
