How to find the Cell-ID of the eNodeB my phone is connected to?
Is there an Android app for that?
@qdii For Android there is the App “Network cell info”
https://www.m2catalyst.com/network-cell-info
There you can see which cell phone antenna your cell phone is connected to.
But only the provider from which the SIM card is.
Agus fágaimíd siúd mar atá sé
Thanks! Do you also know if there’s a way to identify the MME and SGW? I suspect not.
