- Solutionselected by JanineZ
Which remote control is in use? I’m now going to look for the most common remote control and that is the UHD remote control:
Reconnect the remote control:
- Switch the TV-Box off and then on again after a second.
- Wait until the TV-Box has started completely (a television picture appears).
- Press and release the TV-Box WPS button for 3 seconds.
- As soon as this screen appears, press the OK button on the Swisscom remote control. The LED will now flash white until the remote control is connected.
If the connection cannot be established. Please call the Swisscom hotline on 0800 800 800
Greeting
Chris
4 months later
a year later
