How do I change my username
  • Good morning,
    how do I change my username for forums?
    Thanks in advance
    Thanks, I found the option. However, by clicking on Change my password a button appears and disappears immediately. I assume this is a bug. Tested on Firefox and Edge…
    Hello @owegen, thank you for your contribution.
    To change your username, click on your avatar at the top right. Then choose “My profile”, then “My settings” and finally select “Personal information”. Change your first and last name and validate your change with the “Save” button.
    Have a nice week
    Good morning,
    I must really be blind, but it’s impossible to change my username via the path you told me (I’m talking about my username “Zeugriennieff77” and not my photo)
    I don’t think that’s what we mean. Here you can enter or modify the first and last name, but not the user name (in my case “Gaeilgeoir”). This should actually work as @DanielD described, but unfortunately it no longer works. @ThomasS announced in the German-speaking forum that the problem has been forwarded
    Agus fágaimíd siúd mar atá sé
    Hello everyone!
    the problem should be solved, you can change the display name by clicking on the following link: [https://community.swisscom.ch/t5/user/myprofilepage/tab/personal-profile:login](https:/ /community.swisscom.ch/t5/user/myprofilepage/tab/personal-profile:login)
    Liebe Grüsse / Salut et à bientôt / Ciao e a presto / Cheers, see you soon!
    ThomasS
