MySecurity - PAsswortmanager
  • MySecurity - password manager
    As of today the password manager no longer works:
    With the various providers (bank, Migros, etc.) the information stored (user name and password) no longer appears when you log in or password.
    Where could the problem lie?
    • Hello hed
      Thanks for the tip.
      After reinstalling Microsoft Edge, the password vault works properly again. I have not installed any other security software.
      Thank you very much for your efforts and have a nice weekend.
      Don Pedro
    Please excuse the question; but does this apply to a mobile device or a computer?
    Also, is it a browser extension or installed software?
    For example, I often have this with my 1Password manager on the Android device. This is integrated directly into the Samsung keyboard and is not always displayed. I can stop the app and then start it again via the settings.
    Dominik
    Hello DomiP
    Thank you very much for your answer.
    The MySecurity program is loaded on an Acer laptop (Acer Nitro AN517-52 - Windows 11 Home).
    Unfortunately, I don’t understand the question about browser extensions - I’m just a simple user.
    Until now, registration on the insurance website, for example, worked as follows:
    Password safe released at MySecurity, on the website of the corresponding provider a blue icon appeared on the right side when I entered the username and password?, I clicked on it and I was in the customer area.
    The blue thing no longer appears (username and password are currently copied and pasted manually).
    As I said, as a simple user, I don’t dare change anything in the settings etc. With Dr. I searched a lot but didn’t find anything specific.
    Could be something going wrong with an add-on.
    Maybe you have a free tip, gooooooooooooogle something else - maybe I’ll find something that even a DAU (dumbest user to assume) will understand.
    Thank you very much and have a nice day
    @DonPedro53
    Is it possible that you have installed an “AdBlocker” add-on and it is active? When entering passwords I always deactivate it for these functions only, on other pages it is activated.
    Hello WalterB
    Thank you very much for your note.
    No corresponding app found among the apps.
    In the meantime, reinstalled the Firefox browser - it didn’t help.
    Installed the previous browser Microsoft Edge again and lo and behold - everything works again.
    I really hope it stays that way.
    Thank you again and have a nice weekend
    Don Pedro
    @DonPedro53
    Firefox also has a “pop blocker” function which is installed as standard and you may have to deactivate it.
    If a pop-up is blocked, Firefox will show an information bar (unless you have previously disabled the bar as described below) and an icon will appear in the address bar, see link below.
    Had to deactivate this for two users because they had blocked information that was necessary.
    [https://support.mozilla.org/de/kb/pop-blocker-settings-exceptions-problem-solving#w\_was-sind-pop-ups](https://support.mozilla.org/de/kb/ pop-blocker-settings-exceptions-problem-solution#w_what-are-pop-ups)
    @DonPedro53
    Do you have any other security software/antivirus installed in addition to Microsoft Defender integrated into the system? In addition to ad blockers and browser plug-ins, these can also have such undesirable effects.
    Hello hed
    Thanks for the tip.
    Don Pedro
