Router problem (Internet-Box 3)
Hello, I have an internet-box 3 which worked great until a few weeks ago.
Unfortunately it’s been a bit of a disaster over the last few weeks.
Indeed I often have instability problems with my router.
For several weeks I have no longer been able to connect to the web interface, except sometimes when I restart the router.
Note
* Part of my buried line is leaking (5m), but this does not seem to pose any problems according to the technicians.
* I have a lot of connected objects… (probably 50).
* I use an IP in 10.7.*.* with a subnet mask in 255.255.0.0
* Sometimes I could no longer ping IP4s outside my network, sometimes IP6s.
When I ping (from several different machines)
ping internetbox.swisscom.ch
PING internetbox.swisscom.ch(2a02:a90:400e::1 (2a02:a90:400e::1)) 56 data bytes
no response
(my ip6 is in 2a02:1210:707a:…)
When I ping
ping 127.0.0.1
PING 127.0.0.1 (127.0.0.1) 56(84) bytes of data.
64 bytes from 127.0.0.1: icmp_seq=1 ttl=64 time=0.062 ms
Have you also observed any problems over the past few weeks?
