Internet Box 3 - NAS
I connected an NTFS formatted SSD to the USB port on the Internet Box 3 router and everything works (except it’s really slow).
The problem is that I can’t copy files with long names or branches to the SSD from the NAS!
Clearly if I connect the SSD directly to the PC I can copy these files which the NAS instead rejects.
Is there a solution?
Show original language (Italian)
@andy9365
thanks for the contribution
All common formatting protocols (NTFS, FAT32, HFS+ and EXT) on USB hard drives are supported
The length of the file name should not be a problem
NAS Core Storage - Help | Swisscom
specify which operating system is used:
- Windows 10 or 11
- Mac OS
- Other?
Thanks for answering me, I use Windows 11. If I connect the SSD to the PC I have no problems, but if I connect it to the Router this problem occurs.
I noticed that the file name needs to be shorter proportionally to the branching of the folder.
Greetings
