Series recordings cannot be deleted
Hello
The series recording cannot be deleted for a program. I delete the series recording via the TVair website, and the next day the series is marked as recorded again on the TVBox or via the TVAir website. Even the recorded programs of the series, although they were all neatly deleted, are back in the trash the next day (or even a few minutes later…) and take up storage space….
Thanks for hints….
Greeting
Rene
OK, the trash is not the problem… but even recordings deleted in the trash always appear again… and now the series recordings are back…..
If the same series/episode is broadcast again on any channel, you will have it back in the recordings. In this case you not only have to delete the show but also the series or Also cancel the relay.
Yes, I do that too. The selection appears yes, stop individual episode or series recording. Select continuous shooting, seems to work for a moment…. When I check again later, it’s there again…
7 days later
Hello Dorothea,
no, the problem still exists. I delete the series recording in the web app and a little later the recordings are back…
