5 praktische Tipps, um deinen WiFi Switch zu nutzen
@hed
No. Simply put, the Home App on your smartphone is just the user interface. The magic happens inside your Internet Box.
Your Internet Box and its WLAN must therefore be switched on, but the Home App must not be.
Best regards,
Cem from the Home App team
myCloud Experte
Illustration image of a woman with a laptop
@CemÖ
And what happens in the event of a power outage (that’s what @Werner assumed) because then the IB also appears. Does the switch get the correct switching status from the IB as soon as it is up again?
@hed
Exactly. The IB remembers the last state and passes it back to the devices. The information is stored in the IB instead of on the switch.
Best regards,
myCloud Experte
@CemÖ
Certainly better than originally, but if you want/have to get by without a local control memory, the last state alone is not enough, because it may well be that it is wrong, namely if the last switch was made via the WLAN of the Internet box during should have taken place at the time of the Wi-Fi or power outage.
Is the switching rule currently valid according to the plan checked and synchronized again every time the IB is reconnected to the Smart Switch?
@Werner & @hed
Unfortunately, there was a small misunderstanding during my research, which is why I have to correct my statements:
  • If a device is offline (e.g. because the backup leaks), the IB restores the expected state. This means that if you have a rule “switch on the lamp”, but the lamp cannot be reached at this point, then the IB will continue to try according to the rule until it can reach the device in order to establish the “expected state”. But if there is a power outage where the IB is also disconnected from the power, then it will not work as you expected.
  • The Smart Switch has only been adjusted for the above scenario. In order for the switch to switch correctly again, the IB must have been connected to power. In the event of a total power failure, the switch would switch back to “on” as soon as the power is back on.
This misunderstanding arose because we are working on the fact that the IB can restore the last state even in the event of a power failure in which the IB itself is also affected.
I apologize for my incorrect statements. Thank you for your understanding.
Best regards,
myCloud Experte
@CemÖ
Thank you very much for the clarification. Did I understand that correctly, you are working on a solution that will synchronize everything correctly again even after a total power failure? If so, when should this be implemented?
@hed
We are constantly improving the Home App. The behavior described is one of the points we are working on. I can’t give you a date or duration at the moment.
Best regards,
myCloud Experte
6 months later
@Niku
You can’t change that because the Swisscom Smart Switch lacks a local rule storage and when restarted they always go to the “on” position.
If you need more reliable circuits, switch to a better product, e.g. the myStrom switches and also avoid the Swisscom Home App for the control, but use the original control from the manufacturer.
One post just says the following:
The behavior you describe was actually like that in the past. We have updated the switch’s firmware in the meantime so that the Home App restores the previous status after a power interruption. The prerequisite for this is that the Smart Switch is added to the Home App.
@Niku
Read the other comments again, this information was taken back by Swisscom.
Currently, it is still the case that Swisscom Smart Switches should only be used for completely non-critical circuits, certainly not for anything that could lead to a fire hazard if switched incorrectly.
@Werner
If you are already talking about the risk of fire, then, according to the recommendation of building insurance companies, devices that are not in use should be completely disconnected from the power supply, i.e., for example, do not use standby.
My MyStrom control wouldn’t control any heat-generating devices, such as: Coffee machines or fan heaters.
These control the air filter systems and lighting themselves.
4 months later
@Udot2022
Is it about the MyStrom Switch?
https://mystrom.ch/de/
In any case, you can switch the Internet box off and on and then briefly disconnect the Smart Switch from the power supply.
It is important that the WiFi is switched on.
