you can.
The ring also has the function of preventing the device from being placed horizontally.
.....don't think of putting the router on its side!
The situation is monitored (due to overheating) and there is an alarm.
Sufficient cooling is only guaranteed in stationary operation
….keep on rockin' 🤘🏼🤘🏼🤘🏼
- Solutionselected by Thilleuheis30
Cooling is important, so as @POGO 1104 already said:
Laying it on its side and thus covering the stamped cooling grilles is a no-go, but otherwise the position can be varied a little, for example turning it by 90 degrees so that the LAN ports are not facing backwards, but facing upwards.
See the Swisscom example image for the control cabinet installation here:
