Hi everyone,
I'm experiencing a rather annoying issue with my Internet-box 2, here goes the thing:
When I restart it, the overview and LAN tab in the diagnostic shows me that the connection between my PC and the box is 1000Mbit/s ('Connection speed' column), and if I run a speedtest on my PC it goes to 800-900Mbit/s as expected (I have the 1Gbit/s plan). After a few minutes, the network froze for a moment and after that the speed goes down to 100Mbit/s (tested with speed test). If I go back to the internet box, the speedtest performed on it is still 800-900Mbit's, but now in the diagnostic it shows that the connection between my box and the PC is 100Mbit/s and all tests on PC confirm this speed (other connected devices still shows 1000Mbit/s).
I'm using the ethernet cable provided with the box, so I think cable should be an issue, even because it wouldn't test to 800-900Mbit/s on PC right after restart if that was the case.
It seems like the internet-box is slowing the connection speed between it and my PC on purpose, but I couldn't find any option to bring it back or reason why.
Is anyone else facing a similar issue?
I've had this router for almost a year with no change in the configuration/network and only lately had this problem, I guess some update might have cause it. I've reached to the technical support, but they only updated my device which didn't fixed the problem.
Let me know if anyone as any idea/suggestion.
Thank you
Antoine
