HD-Phone Davos - background selectable?
  • I bought the HD Phone Davos today. Now it is a color display. Can’t you choose a background? Just like you can see in the photos everywhere! Only black screen with clock display etc. If not, why a color display????
    Here e.g. Swisscom backgroundHere e.g. Swisscom background
    • @Markus S if you had bought another phone this would have been possible. However, you have a 14-day exchange right. I would rather get a Gigaset S850 HX or S850 A Go.
    @user109 wrote:
    ..I would rather get a Gigaset S850 HX or S850 A Go.
    But it’s a lot more expensive than Davos - but it’s still worth it 😉
    It’s not for nothing that Swisscom is selling off its last Davos for 49.–…….
    ….keep on rockin' 🤘🏼🤘🏼🤘🏼
    @Markus S wrote:
    But I can’t find this Gigaset anywhere on the swisscom shop page? These models
    You can buy the Gigaset 850 mentioned wherever you want. Doesn’t have to be with Swisscom.
    Or the Gigaset models that Swisscom itself offers. https://www.swisscom.ch/de/privatkunden/zubehoer/fixednetwork-accessories_new.html/products/accessories?category=fixTelephones_RES#tab%5Bselected%5D=0
    To add your own pictures, ringtones and other Trallala to the device, you need the Gigaset QuickSync software:
    [https://www.gigaset.com/ch\_de/cms/service/quick-sync-apps.html](https://www.gigaset.com/ch_de/cms/service/quick-sync-apps. html)
    @Markus S wrote:
    Ok. And can I set a background for these models?
    Gigaset:
    Not background images in the actual sense, but you can choose different color schemes for the display.
    What also works is a screen saver with a slide show with your own pictures
    @Markus S
    It should be there in the menu, unfortunately the instructions below don’t show more.
    [https://www.swisscom.ch/de/privatkunden/hilfe/geraet/festnetztelefonie-ip/hd-phone-davos.html#Instructions](https://www.swisscom.ch/de/privatkunden/hilfe/ device/festnetztelefonie-ip/hd-phone-davos.html#Instructions)
    @WalterB wrote:
    @Markus S
    It should be present in the menu, unfortunately the instructions below no longer show it.
    [https://www.swisscom.ch/de/privatkunden/hilfe/geraet/festnetztelefonie-ip/hd-phone-davos.html#Instructions](https://www.swisscom.ch/de/privatkunden/hilfe /device/festnetztelefonie-ip/hd-phone-davos.html#Instructions)
    Yes, can’t find that in the settings? It doesn’t say anything about screen savers either.
