Spiel deine Steam PC-Games auf blue TV
Play your Steam PC games on blue TV
The Steam Link app allows you to play your Steam games on blue TV. We’ll show you how and explain how to connect your controller and computer to the TV-Box. Play games on a giant flatscreen instead of your computer monitor: Now you can thanks to the Steam Link app on blue TV. And there’s no need for a new controller or new games. Simply use your previously purchased games and connect your controller to the blue TV-Box.
How to set up Steam on blue TV
1. Connect your controller to the TV-Box
Connect your controller to the blue TV Box. You can connect your controller to the ‘TV Box 5’, the ‘Swisscom Box’ and the ‘Swisscom Box 21’ via USB cable/dongle or via Bluetooth. You can access Bluetooth pairing via Home button > Settings > System > Google Settings > Remote controls & accessories.
With the ‘TV Box (UHD)’ you can only connect your controller via USB cable/dongle; a connection via Bluetooth is not possible with these boxes.
2. Start the App “Steam Link”
Launch the Steam Link app on blue TV. To do this, go to the home screen > Apps > Games. The app should then detect the connected controller automatically.
3. Connect your Computer to the TV
Launch Steam on your computer. Once you have launched the Steam Link app, the app scans your network. When your computer has been detected, the TV-Box will display a number code. Enter this code into the Steam dialog box on your computer.
Frequently asked questions
What exactly is Steam?
Steam is an online platform for computer games, software, movies and TV series. You can use it to buy computer games, obtain patches, manage digital rights (DRM) and communicate with other gamers. Around 33 million people use the platform daily.
Which controllers can I use to play on the TV-Box?
In principle, any controller that is compatible with Steam will also work with the blue TV-Box. Do be aware, however, that not every Steam game will automatically be compatible with a game controller. You will find a list of games that can be played with a game controller under the “Steam Controller Friendly” menu item in the Steam Link app.
What if I want to connect my computer to the app?
For an optimum connection, you should use a network cable to connect your computer to the Swisscom router. If you use a WLAN connection, you will need a 5GHz connection. Your TV-Box should ideally also be connected to the router by network cable.
What should I do if the app fails to detect my computer?
Steam must be launched on your computer. Check that streaming is enabled under ‘Steam > Settings > In-Home Streaming’ (default setting).
Which operating system should the PC have?
Microsoft: Windows Vista or later
Apple: Mac OSX 10.10 or later
Where can I find additional information?
For more help, visit the Steam Link help page.
Please note: You can only use the above mentioned functions with a TV-Box from Swisscom, but not with the blue TV app.
changed by TamaraA
Illustration image of a woman with a laptop
5 years later
7 months later
