Exactly. There was once a map in which our area (Oberhöfen, Sigriswil etc.) was colored blue in 2014… but what is planned and ultimately implemented are two different things 😉
Is your Anschluss from the Internet box directly from the house connection to just one socket, or does it go via other branches?
Sometimes you can improve the values ​​a little if you run a direct line from the house connection to the socket and disconnect everything else, e.g. Cables to additional sockets.
At the beginning I also had worse values ​​and then I pulled a direct cable from the house connection to the socket without any terminals in between. It wasn’t an extreme improvement but it made a difference.
2 months later
So, a Swisscom technician has now “found out” on site that our socket does not have a point-to-point connection to the house line, as our trusted electrician claimed.
We were now able to increase the DSL profile from 18/1 to 25/5. Great, at least in the upload these are “worlds”.
Unfortunately, it often happens that checks are carried out superficially due to time pressure and the error is suspected somewhere else.:smileyfrustrated:
