Hi Falone
Sorry, I speak no French, hope you can master English.
Can you tell us how’re you connected (mobile-network vs. privat/public WiFi) and what your public-IP address is (check on http://www.whatsmyip.org/).
> “pour moi aussi je ne peux pas avoir accès à mes enregistrements depuis l’Italie….”
does the app opens and you can’t play the recordings OR does it remain at the grey welcome screen? For the 2nd option this means that you probably can’t get a proper internet connection.
Try to:
- use another WiFi network
- or if you have some local friends try to tether (setup a hotspot over another deivce) over their devices
I was lately in Germany and it worked all well for me. Would be strange if there’s a special behavior for Italy…
If everything fails best call the hotline. It might be some account related issue…
