I am having problems setting up the wireless connection to my work laptop. I have to use “Intel PROset/Wireless WiFi Connection Utility” to connect.
The first question it asks is for the “Device Ownership Password” which should be printed on the device but which I eventually found on the packaging box. (I know I have the correct password as there is a checksum message when I enter an incorrect number).
The laptop then communicates with the router and asks for security and password key which I enter and press “next” to complete the registration and connect.
The “registration” process occurs but it fails to connect because it “fails to verify device password”.
I have connected to my WLAN TV which does not need the “device ownership password”.
Can anyone help me on this?
Thanks
