Internet box speed on the LAN
Salu
I have a 200 glass cable and the new equipment from Swisscom.
Now I have found that I can get around 200 Mbit/s but only internet, and only half that in the home network.
With the iMac I then saw that it “only” recognized a 100Base cable. The same with the MacBook. I then connected the MacBook directly to the router using the cable provided.
Idea why this may be?
If I change the cable on the MacBook to 1000Base, it doesn’t recognize the connection.
Do I have to adjust something somewhere?
Thanks
